I sometimes want to increase the output volume on my laptop beyond 100 %. In order to do so I need to open "Sound" in "System Settings". I would like to set a keyboard shortcut to do that. I found out that I can set a custum shortcut in System Settings > Keyboard > Shortcuts with the command "gnome-control-center sound", which will bring up "Sound". So far that works well, but there is a little optimization that I would like but cannot figure out. The problem is this: When I use the shortcut to open "Sound", the focus is not on "Output volume". So before I can modify the output volume with the arrow keys, I need to either click on output volume or hit the Tab key five times, thus moving the focus to output volume. My question is this: Is there something that I can add to the command "gnome-control-center sound" so that the focus is moved to "Output volume" automatically, for example something equivalent to "hit Tab key five times"?
Thanks in advance for your help! Wolfhart
Wolfhart
  • 113
Answers to your question exist here:
How can I reach over 100% volume with a keyboard shortcut?
Personally I prefer this way:
Open the sound settings and with sound settings opened , open also a terminal.
Then try the command below
pacmd set-sink-volume 0 80000
Probably you will see the sound increased further than 100%. Use other values than 80000 until find what serves you.
Now create the shortcuts that you need.
NickTux
  • 17,865
  • 57
  • 66
