15
Possible Duplicate:
How to recover deleted files?
Using Ubuntu 10.10, I have a startup script that automatically removes my 'working directory'. This is a simple folder on my Desktop where I place a bunch of files that I use throughout the day. These are temporary files I need to store just for that one session. In order to keep things clean, my startup script does:
rm -rf /home/user/Desktop/workdir
mkdir /home/user/Desktop/workdir
Works great. Till the moment I had some important files there and forgot to move them before shutting down. A few (2-3) sessions ago this happened and I now realize I need to recover the "workdir" directory. But several new ones have been created and removed in the meantime. What is the best way to recover this - if possible? I read about tools like scalpel but it seems they will scan my whole HD. I know the name of the folder and would like to just look for this workdir folder. What is best?
UPDATE - attempt with Foremost
I have used foremost to try to recover my files. I used:
sudo foremost -a -t doc -i /dev/sda1 -o/home/user/Desktop/foremost
Apparently, I have been removing many documents. So many files were recovered that I had to remove other files on the fly in order to not fill up my hard drive. Over 30GB of XLS/PPT/OLE(?)/Word files were restored. I had to break off the restore process. For Word documents, I have now over 7GB in 3,050 files. How to I get to the right file? They are all numbered, and the date of modification is today for all files.
Also, I need to restore 3 other JPG files as well. This might become an ever larger set of files. How can I only recover what was removed in the last week? Or by using the original filename, is that possible?
Testdisk works great. You could boot from a LiveCD, point testdisk at your drive, navigate to where the deleted files were, and copy them off.
Give a chance to Foremost (here sourceforge project, last v1.5.7 from 2010). It's an easy-to-use forensics program which may be helpful for your case:
sudo apt-get install foremost
Alternative: In this download link you will get a compressed file, inside of which you can find the README file with instructions.
After compiling and installing a description of the command line arguments can be found in the man page:
man foremost
Pablo Bianchi
  • 17,371
I've uploaded a howto video of Foremost to Youtube:
http://www.youtube.com/watch?v=P767rumEIKw
Please enter in terminal:
cat /proc/partitions
Then you can see which partition you need to use with foremost.
Your command will be:
sudo foremost -a -t FILE-TYPE -i /dev/sdb1 -o /home/map/to/recover/files
You should replace sdb1 to your partition.
Keep me informed.
Ilias
  • 1,326
