I upgraded my Ubuntu version from 10.10 to 11.04 alpha and on reboot got an error "The disk drive for / is not ready yet or not present Continue to wait; or Press S to skip mounting or M for manual recovery.
When I press M I get the normal command prompt, how do I get the correct drive mounted??
First guess is that there is an incorrect entry in /etc/fstab. Another possibility (hope not) is that something is wrong with one or more partitions or the drive / controller.
Suggestions:
-boot from liveCD/liveUSB and check integrity of partitions (using gparted for example)
-mount your root partition and take a look at /etc/fstab for anything wrong (you might try using /dev/sd? instead of UUID?)
-worst case scenario, there is a repair install option from the liveCD/liveUSB
You should restart the update manager again. There was an update that was justed released for that not to long ago.
DexterP17
  • 723
Try Root filesystem check fails after power failure during installation
It worked for me.
Pawel
