I can't save changes after editing
sudo vi /etc/network/interfaces
Text before editing:
auto lo
iface lo inet ...
Edited to:
auto eth0
iface eth0 inet dhcp
What key combination or sequence must I press to save this?
You're probably in editing/insert mode. You need to type the following sequence :
: (colon) then press w and finally q to write and quit (or just :w to write without quitting)I usually press ESC and then hold Shift and press z twice. Just like you would like to type two capital Z letters in word editor :) That saves your document and closes your editor.
Check whether you have administrative (root) privileges to edit the file. use this command
whoami
If the result is not "root", then you are not supposed to edit the file.
To login as root user, use the below command
sudo su
or
su
Edit the file,
vi /etc/network/interfeces
After the changes, save the file using
Esc to change the mode:x to save and quit the fileThats all
this question was answered a long time ago, but in case it comes up in search engines again, this link is a nice vim cheatsheet that you might want to bookmark if you use vim a lot.
By the way, You can use :wq to save and exit the file ( you should first press esc key to exit insert or replace mode and then press commands ) and use :q! to exit without saving.
