I was able to connect to the wireless 'AirportFaustin' and others using network icon dropdown menu. I decided to switch from proprietary to open drivers for my wireless card drivers. Once I done it offline.
Since then 'AirportFaustin' wireless network is missing in the network icon dropdown menu. Others are here and work.
- I tried menu item connect to hidden network : I'm still unable to connect. Ubuntu ask again the key.
- Now (I don't know before) this network is listed in the network manager.
- This network is allowed for all users.
- On my computer and others on OSX, I can see and connect without issue to that network.
I would like to be able again to connect to this and others (all) network and that from the network icon dropdown menu.
My issue is different from My wireless network not visible in wireless network list with a Broadcom card because I was able to connect to that network before and I change my network configuration (switch open/proprietary).
I'm using a MacBook Air 4,2 with Ubuntu 12.04.1 LTS and try to connect to a wireless network on a Apple Airport Express (that has been reset to factory config).
I've applied the post-install script on the MacBookAir4-2 page.
I checked /etc/modprobe.d and found two files (the second is directly made by the script. I remember having seen dkms while running the screen too in the Terminal) that blacklist wireless modules :
broadcom-sta-dkms.conf
# wl module from Broadcom conflicts with the following modules: blacklist b44 blacklist b43legacy blacklist b43 blacklist brcm80211 blacklist brcmsmac blacklist brcmfmac blacklist ssb blacklist bcma blacklist bcm43xxblacklist bcma.conf
blacklist bcma
Following the HOWTO post a Wireless issue, my config is :
lspci -nn | grep Broadcom
02:00.0 Network controller [0280]: Broadcom Corporation BCM43224 802.11a/b/g/n [14e4:4353] (rev 01)
iwconfig wlan0
wlan0 IEEE 802.11 Access Point: Not-Associated
Link Quality:5 Signal level:201 Noise level:166
Rx invalid nwid:0 invalid crypt:0 invalid misc:0
lsmod
Module Size Used by
michael_mic 12612 4
arc4 12529 2
usbhid 47238 0
snd_hda_codec_hdmi 32474 1
snd_hda_codec_cirrus 28098 1
snd_hda_intel 33773 3
snd_hda_codec 127706 3 snd_hda_codec_hdmi,snd_hda_codec_cirrus,snd_hda_intel
snd_hwdep 17764 1 snd_hda_codec
snd_pcm 97275 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi 13324 0
snd_rawmidi 30748 1 snd_seq_midi
joydev 17693 0
snd_seq_midi_event 14899 1 snd_seq_midi
snd_seq 61929 2 snd_seq_midi,snd_seq_midi_event
snd_timer 29990 2 snd_pcm,snd_seq
snd_seq_device 14540 3 snd_seq_midi,snd_rawmidi,snd_seq
applesmc 19554 0
input_polldev 13896 1 applesmc
lib80211_crypt_tkip 17390 0
wl 2623795 0
bcm5974 17399 0
snd 79041 16
snd_hda_codec_hdmi,snd_hda_codec_cirrus,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
cfg80211 205774 1 wl
lib80211 14381 2 lib80211_crypt_tkip,wl
btusb 18332 1
uvcvideo 72627 0
videodev 98259 1 uvcvideo
i915 477602 3
v4l2_compat_ioctl32 17128 1 videodev
drm_kms_helper 46978 1 i915
drm 241971 4 i915,drm_kms_helper
soundcore 15091 1 snd
snd_page_alloc 18529 2 snd_hda_intel,snd_pcm
mei 41616 0
i2c_algo_bit 13423 1 i915
mac_hid 13253 0
video 19596 1 i915
apple_bl 13673 0
coretemp 13525 0
bnep 18281 2
parport_pc 32866 0
ppdev 17113 0
rfcomm 47604 12
bluetooth 180153 23 btusb,bnep,rfcomm
binfmt_misc 17540 1
lp 17799 0
parport 46562 3 parport_pc,ppdev,lp
hid_apple 13375 0
hid 99636 2 usbhid,hid_apple
sudo lshw -C network
*-network
description: Interface réseau sans fil
produit: BCM43224 802.11a/b/g/n
fabriquant: Broadcom Corporation
identifiant matériel: 0
information bus: pci@0000:02:00.0
nom logique: wlan0
version: 01
numéro de série: b8:8d:12:08:12:4c
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=5.100.82.112 ip=192.168.0.53 latency=0 multicast=yes wireless=IEEE 802.11abgn
ressources: irq:17 mémoire:a0400000-a0403fff
iwlist scan
lo Interface doesn't support scanning.
wlan0 Interface doesn't support scanning.
lsb_release -d
Description: Ubuntu 12.04.1 LTS
uname -mr
3.2.0-36-generic x86_64
