I'm very new to Ubuntu and I messed up something and I cannot install any packages with apt-get install.
Initially I got this error:
 linux-image-server : Depends: linux-image-3.2.0-36-generic but it is not going to be installed
 linux-server : Depends: linux-headers-server (= 3.2.0.36.43) but 3.2.0.37.45 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And when I tried to run "sudo apt-get -f install" I get this:
dpkg: dependency problems prevent configuration of linux-image-server:
 linux-image-server depends on linux-image-3.2.0-36-generic; however:
  Package linux-image-3.2.0-36-generic is not installed.
dpkg: error processing linux-image-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        dpkg: dependency problems prevent configuration of linux-server:
 linux-server depends on linux-image-server (= 3.2.0.36.43); however:
  Package linux-image-server is not configured yet.
 linux-server depends on linux-headers-server (= 3.2.0.36.43); however:
  Version of linux-headers-server on system is 3.2.0.37.45.
dpkg: error processing linux-server (--configure):
 linux-image-server
 linux-server
Any help is much appreciated because I don't know what to do next.
The way I fixed this was to manually install a newer version of the linux-server package as such:
wget https://launchpad.net/ubuntu/+archive/primary/+files/linux-server_3.2.0.37.45_amd64.deb
sudo dpkg -i linux-server_3.2.0.37.45_amd64.deb
If you're running a 32-bit system you'll need a slightly different URL and package name that you can find here.
Thanks to @Eliah Kagan for his answer here https://askubuntu.com/a/253581/79271 and help with question-meta-issues.
Leopd
  • 643
