When I maximize flash to full screen mode, it lags. The video renders slowly even though the sound is playing smoothly.
I think this might be caused by an issue I'm facing with installing the correct video driver for my computer, an "HP dv4 2154ca" .
I've tried to install the driver a couple of times, but the xorg.conf file is still empty no matter what.
So my question is, why is this file empty, and how could I generate it correctly for my device? Is this the cause of my video rendering problems in flash?
Thanks in advance.
belacqua
  • 23,540
By default, there no longer is an xorg.conf file as everything is autodetected at this point. I can't answer why fullscreen flash is having trouble, based on what I can tell your computer shouldn't have trouble with that.
This bug is very possibly the cause of your problem.
From there, you can try the GPU validation trick :
sudo mkdir /etc/adobe
echo "OverrideGPUValidation=true" >~/mms.cfg
sudo mv ~/mms.cfg /etc/adobe/
But many people have reported that Compiz prevents this fix from working properly, so you might be out of luck until a revised flash-plugin becomes available.
Another option might be to switch to Chromium, as it uses an inbuilt version of flashplugin. To be honest, that just means that Chromium's flashplugin might be a little more up to date, but ultimately it's still just flashplugin, so possibly a dead end.
Scaine
  • 11,229
