I just installed Ubuntu 12.04 on one of 4 machines and am configuring it. When the machine is used in "production" mode it will be headless and will need to boot into single user mode automatically (and start an application). It will need partitions mounted, networking, ssh, etc. I want to test booting into single user mode now so as to get it right before installing/upgrading other machines to 12.04.
I don't know how I missed this when I searched the question but the answer was provided by Mr. Gruber: How to autologin (without entering username and password)(in text mode)
As sudo ,edit the file /etc/default/grub and change:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="text"
Save and then enter the command
sudo update-grub
GRUB is now configured to boot to text mode
As sudo edit the file /etc/init/tty1.conf an dchange the line:
exec /sbin/getty -8 38400 tty1
to
exec /sbin/getty -8 38400 tty1 -a user-name
Where "user-name" is the user who will be automatically logged in.
It appears to work correctly for me.
To get to a GUI envirnment enter startx. Be sure to do this as a "regular" user as using sudo the file .Xauthority will have root as the owner and will cause an endless sequence of requesting passwords ...
Mr. Gruber mentions using tty6 in tty1.conf, I think you must not edit the whatever TTY is in that line unless you have a rescue disk/usb-stick available!
I'll work on the auto start of a script later ...
- 1,241
