I’ve started using rsnapshot as my backup system for my home PC. I really like the idea of hard links and how they are handled. But I can’t find the best workflow. Currently I keep my snapshots on the same partition and will copy the newest snapshot to a pen-drive at the end of the week.
Cloud storage is what I’m looking for. Dropbox doesn’t fit my needs, because there is no way to make Dropbox respect hard links — all snapshots are treated as full snapshots.
Renting a server is pretty expensive, so my question is, are there better alternatives for backup in the cloud? I would like to benefit from hard links and send only incremental backups, just like I do with my local host.
belacqua
  • 23,540
You run rsnapshot on the remote server, it rotates the snapshots using hard links and rsyncs your files from your local machine over ssh.
rsync only sends over the changes so your bandwidth use is minimised, rsnapshot on the server manages the hardlinks to minimise disk space.
What the best cloud solution is depends upon how much disk space you need and other things
dsas
  • 244
Symlinking inside cloud storage is just going to create a copy, not a link, so you're only going to benefit from rsnapshot if you tar the target directory before uploading it.
I admit, I haven't tried this before. You'd have to tar the file in a way that tar's the hardlink as a hardlink and not the file itself (or you'll just end up with another full backup, only compressed).
I'd take a look at man tar and see if it can be done. For example, it appears that the --hard-dereference (follow hard links; archive and dump the files they refer to), is off by default, so as long as you don't specify it, then your tar dump of the latest rsnapshot should be incremental.
Scaine
  • 11,229
I would consider using duplicity. It does basically this, by making TAR backup files and uploading to WebDAV or CloudFiles (SWIFT-style API) systems.
http://duplicity.nongnu.org/
