I installed ubuntu 12.04 after installing windows 7. I have 2 hard disks, one SSD and another HDD. Windows was installed in the HDD, and I wanted ubuntu on my SSD. I chose to have boot files in the SSD where I had installed ubuntu. Initially after the installation it didn't show the dual boot option and directly booted to ubuntu. But after going through some suggestions I used boot-repair and got GRUB repaired/installed. But when I restarted again in the boot options I didn't find the Windows 7 option. I fear that I have accidentally deleted the windows boot files. This is the link I got after boot-repair: http://paste.ubuntu.com/1615740/
Looking at it a bit more, I suspect that running the following command in the Windows 7 installation CD repair console will allow os-prober to find your windows installation.
bootrec /fixboot
After running the command. Reboot, you will most likely still only boot into Ubuntu. So then rerun the boot-repair script. If you've got any trouble please submit the new pastebin.
- 1,592
You can try rebooting after manually modifying your grub menu very, very carefully by opening Terminal and entering sudo gedit /boot/grub/grub.cfg, and inserting the following text at the end of the /etc/grub.d/40_custom section, immediately above the last line containing "END /etc/grub.d/40_custom":
menuentry 'Windows 7' --class windows --class os $menuentry_id_option 'osprober-chain-9E8A1E4F8A1E2475' {
insmod part_msdos
insmod ntfs
set root='hd1,msdos2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos2 --hint-efi=hd1,msdos2 --hint-baremetal=ahci1,msdos2 9E8A1E4F8A1E2475
else
search --no-floppy --fs-uuid --set=root 9E8A1E4F8A1E2475
fi
chainloader +1
If this works, you can make this menu entry permanent by performing the same insertion on the file "/etc/grub.d/40_custom" with this Terminal command: sudo gedit /etc/grub.d/40_custom
This might serve as a workaround if this is because your Ubuntu/Grub somehow cannot detect Windows.
- 11,074
