30
I recently ran chkrootkit and got the following line:
Searching for Suckit rootkit...                   Warning: /sbin/init INFECTED
What does this mean exactly? I heard this was a false positive, what is exactly happening.
Please and thank you.
myusuf3
  • 35,659
It's likely this is a false positive since there's a bug in chkrootkit (supposedly fixed in a later version 0.50-3ubuntu1). Apparently chkrootkit doesn't perform a rigorous enough check.
See: https://bugs.launchpad.net/ubuntu/+source/chkrootkit/+bug/454566
Additionally you could try rkhunter which is similar to chkrootkit.
Some more information: Fortunately, running file `which chkrootkit` shows us that chkrootkit is just a shell script so we can inspect it directly.
Searching for Suckit in the file /usr/sbin/chkrootkit we find:
   ### Suckit
   if [ -f ${ROOTDIR}sbin/init ]; then
      if [ "${QUIET}" != "t" ];then printn "Searching for Suckit rootkit... "; fi
      if [ ${SYSTEM} != "HP-UX" ] && ( ${strings} ${ROOTDIR}sbin/init | ${egrep} HOME  || \
              cat ${ROOTDIR}/proc/1/maps | ${egrep} "init." ) >/dev/null 2>&1
        then
        echo "Warning: ${ROOTDIR}sbin/init INFECTED"
      else
         if [ -d ${ROOTDIR}/dev/.golf ]; then
            echo "Warning: Suspect directory ${ROOTDIR}dev/.golf"
         else
            if [ "${QUIET}" != "t" ]; then echo "nothing found"; fi
         fi
      fi
   fi
The key line is:
Since recent versions of Ubuntu, running that command does produce some output (need to run as root or sudo) :
# sudo cat /proc/1/maps | egrep "init."
b78c2000-b78db000 r-xp 00000000 08:02 271571     /sbin/init (deleted)
b78db000-b78dc000 r--p 00019000 08:02 271571     /sbin/init (deleted)
b78dc000-b78dd000 rw-p 0001a000 08:02 271571     /sbin/init (deleted)
However, this is not an infection by a rootkit. I have also looked at the rkhunter code, and the checks are far more rigorous (testing for all sorts of additional files installed by the rootkit).
I have changed lines 1003,1004 in chkrootkit file not to check perform the check of /proc/1/maps (remember to take a copy first)
if [ ${SYSTEM} != "HP-UX" ] && ( ${strings} ${ROOTDIR}sbin/init | ${egrep} HOME  ) \
             >/dev/null 2>&1
Simon B
  • 1,296
On Kubuntu 13.04 as of 2013-07-31
Running:
cat /sbin/init | egrep HOME
Produces:
Binary file (standard input) matches
AND
Running:
Produces NO output.
Note: Removing the period produces output (changing "init." to "init")
b7768000-b779f000 r-xp 00000000 08:02 399192     /sbin/init
b779f000-b77a0000 r--p 00036000 08:02 399192     /sbin/init
b77a0000-b77a1000 rw-p 00037000 08:02 399192     /sbin/init
So it appears to me that the part checking HOME is the problem.
If one can make the assumption that rkhunter has a valid check, then perhaps the easy route is just to remove this section from chkrootkit and run both rkhunter and chkrootkit?
Seth
  • 59,332
