I just performed a fresh install of 12.04LTS 64-bit, using the alternate CD, with LVM and LUKS. Install went fine but I've noticed a few quirks and was hoping for some pointers/suggestions from the community.
Issues:
  1. On boot, before entering encryption pass phrase, I get a message "ERROR: No video mode activated" (Everything seems to work fine though)
  2. I've got a noticeable but inconsistent "lag/delay" in the launcher/nautilus with the new load. The delay can sometimes be as much as 5+ seconds. Things like the compiz cube/rotator work very fast so I don't think it's a graphics issue.
NOTE: Neither of these issues were present in my original 32bit std install (using the disc from the "Ubuntu Unleashed 2012 edition" book.)
Question:
How do I get rid of the boot error (I'm guessing it's a config issue with grub)?
What would be the best way to further diagnose the "lag" that I'm experiencing?
  • I'm not sure if it's an issue with 64-bit Precise (though I seen several posts reporting the issue with no solutions) or full disk encryption. I know my CPU supports AES-NI, how do I determine if it's enabled/configured properly?
My system:
  • HP Z210 SFF Workstation
  • Intel Xeon E3-1245 quad-core, hyperthreaded
  • Integrated Intel HD 3000 Graphics (registering as "Intel Sandybridge Server" after installing mesa-utils)
  • 8GB RAM
  • 500GB HDD (LVM & LUKS configured using the wizard on the entire drive)
top:
top - 13:37:05 up  2:12,  2 users,  load average: 0.06, 0.21, 0.21
Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
Cpu(s):  0.1%us,  0.0%sy,  0.0%ni, 99.9%id,  0.0%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:   8063752k total,  4227732k used,  3836020k free,    34392k buffers
Swap:  8269820k total,    53548k used,  8216272k free,  3418876k cached
Mateo
  • 8,152
muldune
  • 13
The first is a known bug. There are suggested work arounds on the bug report
https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/699802
Most common is:
Commenting out GRUB_HIDDEN_TIMEOUT and GRUB_HIDDEN_TIMEOUT_QUIET in /etc/default/grub works for me.
GRUB_DEFAULT=GRUB_SAVED_DEFAULT
#GRUB_HIDDEN_TIMEOUT=10
#GRUB_HIDDEN_TIMEOUT_QUIET=
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
GRUB_TERMINAL=console
GRUB_GFXMODE=auto
I do not know the problem with nautilus, but this question has been asked with no obvious solution either. I doubt it has to do with either LVM or LUKS.
Nautilus is really slow
Nautilus is extremely slow
The most common problem is a network share (samba) that is not mounted.
Perhaps running nautilus from the command line might show an error of some kind.
Panther
  • 104,528
