I want to install curl library in ubuntu 12.04 LTS. For that i use the following command sudo apt-get install libcurl4-openssl-dev. but i got the errors as
    ajay@ajay-K54L:~$ sudo apt-get install libcurl4-openssl-dev
    [sudo] password for ajay:
    Reading package lists... Done
    Building dependency tree
     libcurl4-openssl-dev : Depends: libkrb5-dev but it is not going to be installed
                            Depends: librtmp-dev but it is not going to be installed
Whenever i try to install thee dependencies, it shows that packages already installed:
   ajay@ajay-K54L:~$ sudo apt-get install -f libkrb5-dev
     libkrb5-dev : Depends: krb5-multidev (= 1.10+dfsg~beta1-2) but it is not going to be installed
    ajay@ajay-K54L:~$ sudo apt-get install -f krb5-multidev
     krb5-multidev : Depends: libkrb5-3 (= 1.10+dfsg~beta1-2) but 1.10+dfsg~beta1-2ubuntu0.3 is to be installed
                     Depends: libk5crypto3 (= 1.10+dfsg~beta1-2) but 1.10+dfsg~beta1-2ubuntu0.3 is to be installed
                     Depends: libgssapi-krb5-2 (= 1.10+dfsg~beta1-2) but 1.10+dfsg~beta1-2ubuntu0.3 is to be installed
    ajay@ajay-K54L:~$ sudo apt-get install -f libkrb5-3
    libkrb5-3 is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
What do I need to do?
I have tried following command
apt-cache policy libkrb5-3 krb5-multidev libk5crypto3 libgssapi-krb5-2 libcurl4-openssl-dev
and it gives me output as:
ibkrb5-3:
  Installed: 1.10+dfsg~beta1-2ubuntu0.3
  Candidate: 1.10+dfsg~beta1-2ubuntu0.3
  Version table:
 *** 1.10+dfsg~beta1-2ubuntu0.3 0
        100 /var/lib/dpkg/status
     1.10+dfsg~beta1-2 0
        500 http://in.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
krb5-multidev:
  Installed: (none)
  Version table:
     1.10+dfsg~beta1-2 0
libk5crypto3:
  Version table:
     1.10+dfsg~beta1-2 0
libgssapi-krb5-2:
  Version table:
     1.10+dfsg~beta1-2 0
libcurl4-openssl-dev:
  Installed: (none)
  Candidate: 7.22.0-3ubuntu4
  Version table:
     7.22.0-3ubuntu4 0
Braiam
  • 69,112
ajay_t
  • 133
The output you provided on apt-cache policy confirms my suspicion about outdated lists.
For the example of krb5-multidev in 12.04 you should see version 1.10+dfsg~beta1-2ubuntu0.3 as a candidate provided through precise-updates.
krb5-multidev:
  Version table:
        500 http://nl.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
     1.10+dfsg~beta1-2 0
        500 http://nl.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
So, as I already suggested in the comments, run
sudo apt-get update
And you should be all set (retry the installation and also properly update your system!).
gertvdijk
  • 69,427
