65
Since I prefer to use Evolution, I would really like to completely remove Thunderbird from my PC. I already performed sudo apt-get purge thunderbird* but locate thunderbird still lists some hits:
/usr/share/app-install/desktop/thunderbird:thunderbird.desktop
/usr/share/app-install/icons/thunderbird.png
/usr/share/icons/HighContrast/scalable/apps-extra/thunderbird-icon.svg
How can I completely remove it?
muru
  • 207,228
This will completely remove thunderbird from your system.
Here is what went wrong in your case.
  • You will need to wait for the locate database to update, or force update by sudo updatedb before the system picks the changes. Or use locate -e to print only files existing at the time locate is run.
  • The files you see in /usr/share/app-install belong to Ubuntu Software Center.
  • The files in /usr/share/icons belong to the corresponding icon theme.
Mahesh
  • 13,026
A complete purge includes
  1. sudo apt-get purge thunderbird*
  2. rm -r /home/<username>/.thunderbird
then you can reinstall it from zero, otherwise, all the information in .thunderbird will still exist.
sudo apt purge thunderbird*
Probably thunderbird might be installed using snap. You can use,
sudo snap remove thunderbird
