I logged into Ubuntu and my menu bar and launch bar are gone.
I cannot use Ubuntu as there as the only this I see is my wallpaper. I have restarted and it has not done anything.
I can open the terminal, and I can run commands, but that is all I can do.
Here is a picture of my screen with the terminal open (sorry for the bad quality.)
As you can see I don't even have the ability to close, maximise or minimise windows (I can close by using alt+f4 though.)
I have tried various command like alt+f2 and other commands, but these don't appear to work.
Is there a way in the terminal to open the home folder as a window? If I can have a folder open, then I can at least use Ubuntu to an extent.
Thanks in advance.
You could try unity --reset or unity --replace in the terminal. Just log-out or shut-down and hopefully you should see all the Unity features (Launcher etc.)
I've never seen this happen before. It's quite werid.
Hope this helps!
P.S. You could report this as a bug.
horIzoN
  • 1,084
