After I installed experimental Nvidia drivers, Ubuntu will not boot. How can I remove the drivers from recovery mode?
If I choose recovery mode and in the menu choose "root" (drop to root shell prompt), and then try to use the command sudo apt-get remove --purge nvidia-*
it says:
sudo: unable to open /var/lib/sudo/thakang/console: read-only file system
W: Not using locking for read only lock file /var/lib/dpkg/lock
E: Unable to write to /var/cache/apt/
E: the package lists or status file could not be parsed or opened.
I have used login and logged in so my shell now shows :~$
Thank you
