The WVDIAL tutorial is very useful for me, unfortunately I am still not able to connect via wvdial but the other Hybrid connection method was simply Out of the Box.
I am getting below error while running wvdial
sudo apt-get install wvdial
Reading package lists... Done Building dependency tree
Reading state information... Done wvdial is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sudo wvdial --> WvDial: Internet dialer version 1.61
--> Cannot open /dev/modem: No such file or directory
I have run sudo apt-get update first and then run sudo apt-get install wvdial but still no luck...
guntbert
  • 13,475
Mahesh
Finally got the solution, I think this should be share with everuone hence posting....
I found a command : kdesudo wvdial while hunting on Google. Below is the Terminal output.
mahesh@Mahesh-System-Kubuntu:~$ kdesudo wvdial
--> Initializing modem.
--> Sending: ATZ
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Modem initialized.
--> Sending: ATDT#777
--> Waiting for carrier.
ATDT#777
CONNECT
--> Carrier detected.  Starting PPP immediately.
--> Starting pppd at Wed Feb  6 21:50:55 2013
--> Pid of pppd: 5481
--> Using interface ppp0
--> pppd: À[1b]@[08][18]@[08]
--> local  IP address 115.241.164.245
--> remote IP address 220.224.141.129
--> primary   DNS address 220.226.100.40
--> secondary DNS address 220.226.6.104
--> Connect time 0.0 minutes.
Thank you all for your kind support!
Seth
  • 59,332
Mahesh
