10
We are working with a terminal server that is running Xubuntu. Because we have had some issues with saved sessions, we want to turn off the saving of sessions completely.
So far, we have been able to set the default to not saving the session, but in the logout screen it is still possible to save the session. Is it possible to turn off session saving completely (system-wide) so our users won't "accidentally" use it?
Jasper
  • 351
(Tested with Xubuntu 12.04, but with the ppas for Xfce 4.10 and 4.12 installed, but the option I discuss was available for Xfce 4.8)
There is a way to globally disable the option of saving the session, and the best way to achieve it is to use Xfce kiosk mode. One of the available kiosk mode options, buried in the source code for xfce4-session, is SaveSession. If we look at /home/mike/xfce4-session-4.10.0/xfce4-session/xfsm-shutdown.c, we can see the undocumented setting:
/* check kiosk */
  shutdown->kiosk_can_save_session = xfce_kiosk_query (kiosk, "SaveSession");
Firstly, create the kiosk directory with
sudo mkdir /etc/xdg/xfce4/kiosk
and then create and edit the kioskrc with your text editor:
sudo nano /etc/xdg/xfce4/kiosk/kioskrc
Place the following in your kioskrc:
[xfce4-session]
SaveSession=NONE
Now, save the changes and logout and login again as your user to test it. The checkbox option to save the session should have disappeared.
Before the setting is applied, the box is still available:
Afterwards, with kiosk mode active, the option is no longer available:
If you wish to use kiosk mode to globally disable other settings, such as the ability to shutdown or suspend, etc, see my answer here:
the hack from misterich didn't do the trick for me either, somehow it still can write to sessions folder
my solution:
  1. rm -rf "$HOME/.cache/sessions"
  2. touch "$HOME/.cache/sessions"
now there is a file named sessions instead of sessions folder therefore it can't write file to it anymore.
minhng99
  • 111
I ran into the very same problem, but the solution provided by @user76204 didn't do the trick for me.
My Details
$ uname -ir && lsb_release -a && xfce4-about -V
3.13.0-24-generic x86_64 No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 14.04 LTS Release: 14.04 Codename: trusty xfce4-about 4.11.1 (Xfce 4.10)
My Solution
I fully admit that this is an ugly, ugly hack
  1. Clear out the sessions directory:
    find "$HOME/.cache/sessions" -type f -print0 | xargs -0 rm -f
  2. Remove write permissions by setting octal permissions on "$HOME/.cache/sessions"
    chmod 500 "$HOME/.cache/sessions"
Thus, sessions cannot be saved. This approach does have one advantage, however: Should you want something set in a session at a later date:
  1. Reset the permissions on the folder
    chmod 700 "$HOME/.cache/sessions"
  2. Fire up XFCE session manager:
    xfce4-session &
  3. set/save/configure whatever...
  4. Save the session
  5. Remove write permissions by setting octal permissions on "$HOME/.cache/sessions"
