My laptop is Dell Vostro 2520. I tried both Xubuntu and Ubuntu on it, I've used 12.04 & 12.10. WiFi fails to work in all the cases - when i try to switch WiFi by a hotkey (fn+f2) the Bluetooth icon appears in the system tray but the light for the WiFi on lower left corner panel doesn't turn on.
I tried the solution of connecting to the network via cable:
sudo apt-get install linux-headers-generic
sudo apt-get install --reinstall bcmwl-kernel-source
sudo modprobe wl
from the similar thread How do I get an Acer Npilfy 802.11 (BCM43225) wireless card working?
Could you help me?
Many thanks in advance!
Update 1
It wasn't clear to me is @mikewhateve talking about one or two commands in the console. i tried both
halfros@halfros-Vostro-2520:~$ lspci -nn | grep Net, rfkill list all
grep: rfkill: No such file or directory
grep: list: No such file or directory
grep: all: No such file or directory
07:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
halfros@halfros-Vostro-2520:~$ rfkill list all
Update 2
$ sudo dpkg -i | grep bcmwl-kernel-source
dpkg: error: --install needs at least one package archive file argument
Type dpkg --help for help about installing and deinstalling packages [*];
Use `dselect' or `aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through `less' or `more' !
Update 3
 dpkg -l grep bcmwl-kernel-source
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version      Architecture Description
ii  grep           2.12-2       amd64        GNU grep, egrep and fgrep
dpkg-query: no packages found matching bcmwl-kernel-source
Elmor
  • 355
Thanks @mikewhatever the answer was found. i copy it here to save time for anyone interested in this issue
If you have a 64-bit system and the device I mentioned, then I suggest this package: http://jas.gemnetworks.com/debian/pool/main/w/wireless-bcm43142/wireless-bcm43142-dkms_6.20.55.19-1_amd64.deb
First install the prerequisites:
sudo apt-get install linux-headers-generic build-essential dkms
Then install the package with:
 cd Desktop   <--or whemikewatrever you downloaded the deb
    sudo dpkg -i wire*.deb
    sudo modprobe wl
Elmor
  • 355
