I'm trying to convert .rpm to .deb using alien.
sudo alien -k libtetra-1.0.0-2.i386.rpm
Alien says that:
libtetra-1.0.0-2.i386.deb generated
But when I check the folder - there is just original .rpm and no .deb. Also - I can see that for a split second there is a .deb file in a folder. so it looks like alien create .deb and deletes it right away.
I suspect that it's maybe because I run 64 bit os and package is 32?
Can somebody explain why alien deletes .deb automatically?
Verbose output:
LANG=C rpm -qp --queryformat %{NAME} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{VERSION} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{RELEASE} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{ARCH} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{CHANGELOGTEXT} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{SUMMARY} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{DESCRIPTION} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{PREFIXES} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{POSTIN} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{POSTUN} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{PREUN} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{LICENSE} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qp --queryformat %{PREIN} libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qcp libtetra-1.0.0-2.i386.rpm
rpm -qpi libtetra-1.0.0-2.i386.rpm
LANG=C rpm -qpl libtetra-1.0.0-2.i386.rpm
mkdir libtetra-1.0.0
chmod 755 libtetra-1.0.0
rpm2cpio libtetra-1.0.0-2.i386.rpm | lzma -t -q > /dev/null 2>&1
rpm2cpio libtetra-1.0.0-2.i386.rpm | (cd libtetra-1.0.0;  cpio --extract --make-directories --no-absolute-filenames --preserve-modification-time) 2>&1
chmod 755 libtetra-1.0.0/./
chmod 755 libtetra-1.0.0/./usr
chmod 755 libtetra-1.0.0/./usr/lib
chown 0:0 libtetra-1.0.0//usr/lib/libtetra.so.1.0.0
chmod 755 libtetra-1.0.0//usr/lib/libtetra.so.1.0.0
mkdir libtetra-1.0.0/debian
date -R
date -R
chmod 755 libtetra-1.0.0/debian/rules
debian/rules binary 2>&1
libtetra_1.0.0-3_i386.deb generated
find libtetra-1.0.0 -type d -exec chmod 755 {} ;
rm -rf libtetra-1.0.0
Very Verbose output
libtetra
1.0.0
i386
- First RPM Package
Panasonic KX-MC6000 series Printer Driver for Linux.
This software is Panasonic KX-MC6000 series Printer Driver for Linux.
You can print from applications by using CUPS(Common Unix Printing System)
which is the printing system for Linux.
Other functions for KX-MC6000 series are not supported by this software.
(none)
(none)
(none)
(none)
GPL and LGPL (Version2)
(none)
Name        : libtetra                     Relocations: (not relocatable)
Version     : 1.0.0                             Vendor: Panasonic Communications Co., Ltd.
Release     : 2                             Build Date: Tue 27 Apr 2010 05:16:40 AM EDT
Install Date: (not installed)               Build Host: localhost.localdomain
Group       : System Environment/Daemons    Source RPM: libtetra-1.0.0-2.src.rpm
Size        : 31808                            License: GPL and LGPL (Version2)
Signature   : (none)
URL         : http://panasonic.net/pcc/support/fax/world.htm
Summary     : Panasonic KX-MC6000 series Printer Driver for Linux.
Description :
63 blocks
    date -R
Mon, 07 Feb 2011 11:03:58 -0500
    date -R
dh_testdir
dh_testdir
dh_testroot
dh_clean -k -d
dh_clean: No packages to build.
dh_installdirs
dh_installdocs
dh_installchangelogs
find . -maxdepth 1 -mindepth 1 -not -name debian -print0 | \
        xargs -0 -r -i cp -a {} debian/
dh_compress
dh_makeshlibs
dh_installdeb
dh_shlibdeps
dh_gencontrol
dh_md5sums
dh_builddeb
libtetra_1.0.0-2_i386.deb generated
Resolution
Oh well. It looks like it's perhaps a bug? or I don't know. I simply installed 32-bit version of Ubuntu in VirtualBox and converted package there. For some reason I couldn't convert 32-bit package in 64 OS. and that is that.
If someone ever finds the reason ffor this behavior - plz. post somewhere in comments.
Thanks
Stann
  • 15,416
It almost sounds like Alien is being run with the -i flag:
-i, --install
    Automatically install each generated package, and remove the package
    file after it has been installed.
However, from your question that doesn't appear to be true. Different architectures may be the issue here. Try debugging the process further with -v or if that doesn't yield anything: --veryverbose. If you're unable to determine the issue from those flags post the output of each in your original question.
Lastly, try installing ia32-libs package which places a lot of common 32bit shared libraries on your machine. This assists in compiling and running 32bit programs on 64bit machines.
Marco Ceppi
  • 48,827
not the most sexy trick, but you can do the following:
mv /bin/rm /bin/rm_renamed
ln -s /bin/echo /bin/rm
alien --scripts your_rpm.rpm
mv /bin/rm /bin/rm_bad_link
mv /bin/rm_renamed /bin/rm
rm /bin/rm_bad_link
devav2
  • 37,290
Ben
