Just use melt and instead of giving it a video file use an image file that you either join to the video at the begining or end (remember to give it an out= time in frames to define the time length of the image) or that you blend with a filter.
A lot of examples and uses of other commands too:
To utilize images (say, .png) in a video edit composition:
melt \
video.avi in=30 out=79 \
test.png in=0 out=15 \
-blank 15
Note that for test.png, in= parameter doesn't need to be 0 - however,
the image will be displayed for out-in time; in this case, it would be
easiest to simply leave the in=0 parameter out altogether.
The youtube playlist that you mention in your comment is really good and simple to understand. It gives good examples of the commands and also of how to write simple scripts in Bash to iterate the use of filters and mixes over multiple files. Worth watching!
Here it explains how to add to your video text using gstreamer:
gst-launch filesrc location="<Filepath>" ! textoverlay text="Title : Hello" valign=top halign=left ! xvimagesink
