How do I install the shell "z" script directory jumper on Ubuntu 12.10?
In the z readme, after line 50, it says:
Installation:
Put something like this in your $HOME/.bashrc or $HOME/.zshrc:
. /path/to/z.shcd around for a while to build up the db.
You need to download the z.sh file to a directory of your choosing, then tell your .bashrc where it is, so your terminal can find it. (The same applies for z-shell, which is just another shell system.) Then, after you use bash for a while, z will know your favorite locations.
- 17,371
- 1,887
You can download and add to *rc files using command line as so
# Download to latest to home dir
wget "https://raw.githubusercontent.com/rupa/z/master/z.sh" -O "~/z.sh"
Add to .bashrc
echo "source /path/to/z.sh" >> ~/.bashrc
Add to .zshrc
echo "source /path/to/z.sh" >> ~/.zshrc
- 17,371
- 171
From here
Download
wget https://raw.githubusercontent.com/rupa/z/master/z.sh.Install
printf "\n\n#initialize Z (https://github.com/rupa/z) \n. ~/z.sh \n\n" >> .bashrc. This command appends. ~/z.shto your .bashrcfile, which in turn tells it to run Z upon start-up.- Reload shell
source ~/.bashrc.To test how Z works, browse to these directories:
cd /etc/systemd/system cd /usr/share/nano cd /etc/kernel/postinst.d cd ~Now, from your terminal, type in
z sysand push the tab button, then enter. Next, typez nanoand hit the tab button, then enter again. You will see in both cases that Z automatically knew tocdinto the first and second directories where we initially browsed.Using Z with Zsh
- Run
printf "\n\n#initialize Z (https://github.com/rupa/z) \n. ~/z.sh \n\n" >> .zshrc. This command appends. ~/z.shto.zshrcfile, which tells it to run Z on start-up.- Reload shell
source ~/.zshrc.
Using Z with Zsh + Oh My Zsh
Just add z to the plugins list in ~/.zshrc
plugins=(
git
z
Download the z script to your home directory:
wget https://raw.githubusercontent.com/rupa/z/master/z.sh -O ~/.z
Then:
source ~/.zshrc
When installing scripts like this (shell augmentation), it is usually a good idea to install them to /etc/profile.d. To download and install in a single step, you can use the following command:
sudo curl https://raw.githubusercontent.com/rupa/z/master/z.sh \
-o /etc/profile.d/z.sh
Some of the advantages of installing your shell modifications on /etc/profile.d:
- It will be available for all shells and users;
- There's no need to
chmod +x; - It is easier to uninstall (just remove the file);
- It is easier to remember where you put them.
- 125
