I am following the directions on the page for Ubuntu App Development: http://developer.ubuntu.com/get-started/gomobile/
Command 1:
sudo add-apt-repository ppa:canonical-qt5-edgers/qt5-beta1 && sudo apt-get update && sudo apt-get install qt5-meta-full && echo 'export PATH=/opt/qt5/bin:$PATH' >> ~/.bashrc
Output 1:
Fetched 745 kB in 3s (204 kB/s)
Reading package lists... Done
Building dependency tree
qt5-meta-full is already the newest version.
The following packages were automatically installed and are no longer required:
 libtiff4 libtiffxx0c2 linux-headers-3.5.0-17 linux-headers-3.5.0-17-generic
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Command 2
 sudo add-apt-repository ppa:ubuntu-sdk-team/ppa && sudo apt-get update && sudo apt-get install qt-components-ubuntu qt-components-ubuntu-demos qt-components-ubuntu-examples qt-components-ubuntu-doc notepad-qml
Output 2
  qt-components-ubuntu : Depends: libqt5core5 (>= 5.0.0) but it is not installable
                    Depends: libqt5gui5 (>= 5.0.0) but it is not installable
                    Depends: libqt5qml5 but it is not installable
                    Depends: libqt5quick5 but it is not installable
As specified, I set the PATH to include /opt/qt5/bin. I was wondering if this issue was familiar to anyone. Thanks a lot for your time.
Tachyons
  • 17,455
This started happening today to my existing install as well. My guess is Canonical are changing the package dependencies either preparing for the final Qt5 release or revamping the Qt5 beta.
Keep an eye on ppa:canonical-qt5-edgers/qt5-beta1 and ppa:canonical-qt5-edgers/qt5-proper as well as for updated instructions on http://developer.ubuntu.com/get-started/gomobile/
EDIT: The build log from yesterday indicates that 'deb http://ppa.launchpad.net/canonical-qt5-edgers/qt5-proper/ubuntu quantal main' is being used now.
I guess we'll just have to wait for updated instructions.
Thomas Ward
  • 78,878
I had the same problem and asked for help at the #ubuntu-phone irc. They came up with the solution to use the ppa:canonical-qt5-edgers/qt5-proper PPA from launchpad. Therefore just add https://launchpad.net/~canonical-qt5-edgers/+archive/qt5-proper to the sources.list. After that run
    sudo apt-get update
and you should be able to complete the instructions from http://developer.ubuntu.com/get-started/gomobile/.
Thomas Ward
  • 78,878
Phidelux
  • 772
Adding
to my software sources fixed the install process. Now to see if it all works.
Update: Not quite there yet, the qml viewers seem a little off.
qmlscene: could not find a Qt installation of ''
John
