Lubuntu uses PCmanFM as it's default file manager. I want to access my samba share with PCmanFM to upload and download files. I've already installed the "samba" and "cifs-utils" packages and thier dependancies. Installing them seems to allow me to see the windows network which I can open and see my workgroup, but I cannot open the workgroup. It looks like nothing happens when I click on it, but after a minute or two I start to get "Failed to retrieve share list from server" and "The specified location is not mounted" messages. I should have to authenticate a username and password before I can access the samba share, but no dialog comes up asking for any info.
How can I get PCmanFM to access my shared files?
Seth
  • 59,332
starrysky
  • 177
This should work:
smb://<machine_name/ip>/filepath/filename
in the PCmanFM address bar.
e.g:
smb://192.168.1.111/some_folder/sub_folder/file.pdf
Courtesy: https://help.ubuntu.com/community/Lubuntu/PCManFM#Browse_Windows_PCs_with_Samba
Update:
If you want to connect as a particular user, use
smb://username@smb_server/some_folder
Under Lubuntu 14.10, this brought up a password dialog and then connected with the expected ownership and privileges.
Courtesy: Comment by Randall Cook
FYI, PCmanFM mounts samba shared devices in /run/user/userid/gvfs (id -u can help to find user id) so after mounting Samba shares using PCmanFM, we can also access files/directories using console
scls
  • 103
saji89
  • 12,187
I had the same issue on Lubuntu 17.10 and smbclient -L WINDOWS-PC always returns this error:
 protocol negotiation failed: NT_STATUS_INVALID_NETWORK_RESPONSE
By adding the following line in global settings of /etc/samba/smb.conf, it solves my issue for smbclient and pcmanfm:
[global]
    client max protocol = smb3
