On Ubuntu, how do I get a list of network connections my computer has made in the last few days? Is there a easy way to do this?
Asked
Active
Viewed 1.3e+01k times
41
You can't get ended connections unless you were logging them. To get the current connections:
# sudo netstat -tupn
This will show the current opened source and destination ports with IPs.
To get more details about the contents of the connections, install tcpdump if it's not installed and run:
# sudo tcpdump -X -i eth0
And you can run that in the background and write the output to a file.
Islam
- 660
If you are loooking for a list of ports you can use:
netstat -tupn | grep -E ":(22|80|8000) .*"
or
netstat -tupn | grep -E ":(22|80|8000) .*ESTABLISHED"
Gonzalo
- 131
- 4
