28
I'm still a little new to Ubuntu and was wondering how I can copy files, in this case Aptana Studio, to /usr/local/ without being denied.
Is there a way to do it in terminal? Or a way to allow myself permission? I should add that I am using 10.10 Desktop edition, not server.
Jorge Castro
  • 73,717
There are a couple of different ways
  1. Open Nautilus with sudo by typing sudo -H nautilus in terminal then copy the files as you would normally. Warning: I would close nautilus straight after so you don't accidently use it for moving normal files.
  2. Open terminal and type sudo cp file1 /usr/local/ obviously replacing file1 with aptana
  3. Add open as admin option to nautilus and open the local folder by right clicking and selecting open as administrator.
Zanna
  • 72,312
Allan
  • 11,672
10
/usr/local is a directory belonging to the user root, so you need to use sudo to achieve your end:
sudo mkdir /usr/local/mydir
sudo cp file.txt /usr/local/mydir
for example.
Zanna
  • 72,312
enzotib
  • 96,093
