I've installed lightread which works fine. I can open lightread from dash but there is no lightread command in terminal. May be the command to lightread is something other than lightread. So, what is the command to run lightread?
Asked
Active
Viewed 106 times
TheKojuEffect
- 3,465
actually the command to run it is
lightread
However probably you have the launcher missing. Try running the menu editing tool. Type
alacarte
Then go to the section "internet" (or the one you want to create the shortcut in), click on "new element" button (top right of the program window) and fill the boxes:
In program: Lightread
In command: lightread (attention to the minuscules)
Description: Is a great google reader client
Now try to search it from the dash, for sure it will be there! :)
Cheers! :)
Rho
- 11
