I am trying to create a script to run vlc to play (or queue if a playlist is already present) some videos.
so far in my ~/bin/ folder I have created a file ``myvlc'' with the following command:
#!/usr/bin/env bash
vlc --http-port 54444 %U
This works as a command if I set it as launcher command in an icon, but it doesnt work if from the command line I type: myvlc ~/Videos/Some\ Folder/video.avi
How can I modify this bash script and make it work?
lucacerone
  • 1,721
Suggestion: use Bash aliases
Aliases allow you to append more arguments and 'overrule' current commands too. For example, this alias:
alias hvlc='vlc --http-port 54444'
will make
hvlc -v /path/to/my/movie.mkv
to become
vlc --http-port 54444 -v /path/to/my/movie.mkv
If you like the alias, install it permanently:
echo "alias hvlc='vlc --http-port 54444'" >> ~/.bash_aliases
The default ~/.bashrc file installed for users in Ubuntu will source the ~/.bash_aliases file by default.
More about aliases in an earlier answer of me.
About your script
It's not passing the arguments to the vlc command as given to the "parent" Bash script. To fix this, make the line
vlc --http-port 54444 $@
The $@ is the Bash magic for "all arguments". The %U is only used in .desktop files in GUIs and is a magic string to place the URL to be opened.
gertvdijk
  • 69,427
