17
I've got an IcyBox USB hub/card reader combo in my computer, running Ubuntu 12.10.
It's got an issue with SD cards. It always mounts them read-only, regardless of the write-lock switch. This is observed across many SD cards that otherwise work, and crucially occurs for a microSD in an adapter, where the microSD was fine in the microSD slot in the reader.
Anyone got any ideas as to what's going on and how I can fix it?
guntbert
  • 13,475
TimD
  • 333
6 Answers6
13
It sounds to me to be a permissions issue. I've come across this myself with my Linux Mint 14 (Cinnamon) install, which I believe is based on Ubuntu 12.10.
First thing to do is to check the permissions on the hardware device mounting your card. You'll need to find the device name. To do this run the following command:
sudo fdisk -l
Your device will probably be something along the lines of /dev/sdb1, in my case the SD Reader was /dev/mmcblk0p1.
Next you need to get the permissions on this device:
sudo ls -l /dev/mmcblk0p1
Replace "/dev/mmcblk0p1" with your device location. The output will look something like this:
brw-rw---- 1 root disk 179, 1 Feb 3 21:58 /dev/mmcblk0p1
This tells us the device is owned by User 'root' and group 'disk' You need to be a member of group 'disk' to be able to write to the SD card. You can check which groups your a member of with
groups username
In my case I was not a member of the 'disk' group, I rectified this with
sudo usermod -G disk --append username
This adds the group 'disk' to your user's groups, which should allow you to now read & write to the SD card
Cage
  • 345
It's likely that the SD card was removed without ejecting it properly, and the file system is marked as dirty. The media mounting system checks the dirty flag when it sees the device, and by default mounts read-only when there's an error (mount option errors=remount-ro).
You can check this by looking in the syslog (use sudo less /var/log/syslog) for something like this:
May 17 14:56:47 myhost udisksd[800]: Mounted /dev/sdc1 at /media/susan/5EC4-D59E on behalf of uid 1000
May 17 14:56:47 myhost kernel: [1017820.273269] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
In this case, it was a DOS FAT filesystem, and can be fixed with
dosfsck -l -t /dev/sdb
Remove dirty bit (y) Answer Yes for ALL
Once complete, then eject the card and put it back in.
SusanW
  • 185
In my case Ubuntu auto-mounted the SD Card into a directory it created that didn't have write permissions.
  • Once mounted (accessible but read-only), find the mount point: /media/{username}/{sd-card name}
    (in my case this was: /media/andrew/SDCard - you can find this by right-clicking on the drive, selecting 'Properties' and looking for 'Mounted on', or by typing mount -l in a terminal)
  • Open a terminal and type the following: sudo chmod 777 /media/{username}/{sd-card name}
    e.g. sudo chmod 777 /media/andrew/SDCard
The SD card is now writable
Andrew
  • 1,099
Get hold of a PC running windows, download a program called SD Formatting, install and reformat the SD card, making sure the option is set to "ON", it will then be recognised on a Linux machine! without the read only option.
I've had this problem. I noticed other devices were able to write to the SD card.
It turned out to be a bad SD card adapter (the kind with the ro/rw switch).
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
blarn
Open terminal by hitting Alt+Ctrl+T and run:
sudo mount --options remount,rw /dev/sdd
Replace /dev/sdd with your SDHC drive, you can find it using fdisk -l.
Jack Mayerz
  • 1,687
