I'm looking at a web application that needs ACLs enabled. Are there any benchmarks or other documents to show what potential impact ACL does{n't} have when the file system is under heavy load?
Also, does it matter what filesystem you use with ACLs?
Bryan Agee
  • 3,376
I got stuck with a similar question and found this Usenix article which has a section EA and ACL Performance discussing a comparison of time taken with and without ACLs. Also compares this for different file systems, which shows interestingly that XFS-512(inode size) and JFS do not cause a performance impact.
So definitely the ACLs cause a performance degradation depending on the file system type but it also depends on your production load, server resource and how much overhead is acceptable.
beginer
  • 287
