I recently installed ubuntu 12.10 on my Macbook Pro mid 2012 alongside Mountain Lion using rEFIt boot. I am having trouble connecting to wireless network. When I click the internet icon at the top of the menu bar, no networks are shown and when I try to manually connect through edit connections, it doesen't work. I did not instal any drivers for anything, but the trackpad (even the two finger scrolling works) , brightness keys, volume keys and keyboard illumination led brightness works. So.. I am guessing it came with some drivers.
Here are my results of some things I typed into terminal
  1. nm-tool
    State: disconnected
    Device: eth0 -----------------------------------------------------------------
    Type:              Wired
    Driver:            tg3
    State:             unavailable
    Default:           no
    HW Address:        A8:20:66:2A:05:23
    Capabilities:
    Carrier Detect:  yes
    Wired Properties
    Carrier:         off
  2. sudo lshw -C network
    PCI (sysfs)
    *-network
    description: Ethernet interface
    product: NetXtreme BCM57765 Gigabit Ethernet PCIe
    vendor: Broadcom Corporation
    physical id: 0
    bus info: pci@0000:01:00.0
    logical name: eth0
    version: 10
    serial: a8:20:66:2a:05:23
    capacity: 1Gbit/s
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt
    10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.123
    firmware=57765-v1.37 latency=0 link=no multicast=yes port=twisted pair
    resources: irq:16 memory:a0400000-a040ffff memory:a0410000-a041ffff
    *-network
    description: Network controller
    product: BCM4331 802.11a/b/g/n
    physical id: 0
    bus info: pci@0000:02:00.0
    version: 02
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress bus_master cap_list
    configuration: driver=bcma-pci-bridge latency=0
    resources: irq:17 memory:a0600000-a0603fff
Thank you, any help is great, I am only 14 and I just need a bit of help.
Also, if this doesn't work, will an older version of Ubuntu or a different Linux work?
Seth
  • 59,332
Please get a temporary wired ethernet connection. Open a terminal and do:
sudo apt-get install linux-firmware-nonfree
sudo modprobe -r b43 && sudo modprobe b43
It should now be working.
chili555
  • 61,330
