22
I'm looking for an application that drops output in a portable format, maybe export as an image file so I can flowchart some application designs and submit them to my boss for professional review. From what I've seen dia is about the de-facto standard for linux flowcharting, but maybe some of you out there in askubuntu land have some other suggestions for me to examine.
Please keep in mind it has to offer a professional / attractive look on the final product. Maybe some color coordination of the options (logic structures are all purple, input statements are orange... for example)
lazyPower
  • 5,451
7 Answers7
17
you can use for Flow Chart Design:
  • LibreOffice Draw (Formerly OpenOffice Draw) (You can give it colors to the elements)
  • Kivio (From the KDE KOffice Suite)
  • Inkscape
If you are talking about Gantt Flow then
Luis Alvarado
  • 216,643
I would add inkscape Install inkscape to the possibility list. Output is svg by default, so it is very portable will render well. (Flowchart hint -- use the connector tool.) If you are comfortable with the interface, inkscape is wonderful and very flexible. SVG/XML documents created in the software are also hand-tweakable, if that's your cup of tea.
Another tool that I discovered from this askubuntu is pencil.
Here's one of the threads discussing it: FOSS GUI Prototyping
There are also some community-provided flowcharting stencils on their stencils page. I'm not sure if this is what you need, but it might be worth checking out.
belacqua
  • 23,540
I use Google Docs for creating flow charts. It's not open source, but it is free (as in beer) and does create attractive graphics. Here's an example of a simply chart
It's not very complex in that it doesn't 'know' about different types of charts - it's intended as a sandbox that you can use to create whatever chart you need. You have a wide range of shapes that you can place on the canvas, with a wide range of colours with which to fill them, easily selectable from a dropdown menu in the toolbar. It also allows you to 'snap' your shapes to an invisible line that has them aligned with each other - just place a few shapes on the canvas then start moving another one around and see what I mean.
You can download the finished images as PDF, SVG, PNG and JPG files.
You will need a Google account to use it, but you have the added bonus of not having to worry about saving them periodically, and you don't risk loosing them which, if they're for work, will be a great help.
Personally, I've never liked Dia. I've always had to fight with it to get it to do what I want, and it always made me do things in incredibly convoluted ways. The 'drawing' feature in Google Docs just feels 'right'.
Perhaps xmind is an option. It's much more than just a Mindmapper.
Examples:
http://www.xmind.net/share/test00/flow-chart/
http://www.xmind.net/share/andi_iium/ip-geolocation-techniques/
Clausi
  • 5,057
Personally I'm a fan of tcm, Toolkit for conceptual modeling (it's available from the repositories). Mainly because the file format is textual, so you can edit it with a text editor if need be, and you can export it to PS and EPS which goes great with LaTeX, and FIG which allows you to edit it with xfig. It also enforces UML standards, disallowing you to stray from them. The GUI and resulting models do not look very "pretty" though.
If you need to cooperate with people using different operating systems (like Windows and Mac OSX), consider umlet (also available from the repositories). It's written in java, and the only one I've found that is easily usable and installable on Windows, OSX and Linux. It also allows you to export to useful formats, like SVG, EPS and PDF, as well as the common image formats.
geirha
  • 47,279
There is another software to make flow charts called yED.
Check it out.
Mochan
  • 1,708
Chris X
Meanwhile there is a desktop version of draw.io based on electron which is also available as a .deb package. It seems that it is also open source. Personally I find this the most easy to use solution compared with most of the other noted programs.
T-Dawg
  • 121
