I cannot find the drivers for AMD Radeon HD 7730M (Dell Inspiron 15R Special Edition) on the AMD website! can someone please send me the link to download any open source drivers if available?
Also the fan doesn't stop running when booted into Ubuntu (not the case with Windows 8). Any solutions ?
Sathya
Ubuntu 13.10 now supports Hybrid Graphics. If you have Ubuntu 13.10 and Radeon hybrid graphics you can install the driver and catalyst control center as easy as follows:
sudo apt-get install fglrx fglrx-pxpress
Then your fan problem and driver issues will be gone. And after you can start Catalyst Control Center and switch your graphics card. You can start catalyst control center in dash by shortcut or through terminal as follows:
sudo amdcccle
--remember to run Catalyst Control Center as root to switch graphics--
PS:
I really don't know whether above works with Ubuntu 13.04 or earlier. For those old systems you can just turn off the discrete graphics card (ATI Radeon Graphics card) to solve overheating, fan issue and increase battery life.
You can just turn off ATI card as follows:
chmod -R 705 /sys/kernel/debug
chown -R $USER: /sys/kernel/debug/vgaswitcheroo
echo OFF > /sys/kernel/debug/vgaswitcheroo/switch
You can then add the 3rd command into /etc/rc.local file before exit() command so that it executes everytime when system starts. This also worked for me in Ubuntu 13.04.
Deepal
  • 1,676
http://support.amd.com/de/gpudownload/linux/Pages/radeon_linux.aspx
This is the link for the radeon driver!
And about the fan, you can try this solution.
https://answers.launchpad.net/ubuntu/+question/204193
In addition to @Deepal's comment - you also would want also edit your GRUB file with one line in GRUB file /etc/default/grub
old:
GRUB_CMDLINE_LINUX=""
fix:
GRUB_CMDLINE_LINUX="quiet splash nomodeset"
Save and exit and proceed accordingly as per above's suggestion.
source: [link] ATI Radeon HD 6750 Ubuntu 13.10
Faron
  • 1,418
  • 14
About the fan, same laptop here.
Try installing the i8kutils package
http://ubuntuforums.org/showthread.php?t=842775
Then use i8kmon
http://manpages.ubuntu.com/manpages/gutsy/man1/i8kmon.1.html
