I've never used Linux before and I can't even get it running heh. Basically I am using Ubuntu 12.10 in virtual box, at that least that's what I think I'm doing. Currently I am just watching this background picture though and I can move the pointer around but there's no menu bar or anything. I tried some hotkeys as well but nothing pops up and the only thing I've seen so far is Compiz crashing.
So my question is basically, how do I even get it running? I'd take a screenshot but there's nothing to show.
Specs:
  • Intel Core i5 2500K which should be like 3.3GHz I believe.
  • 8192MB memory.
  • NVIDIA GeForce GTX 560 Ti
  • Virtual Box specs:
  • Processor: 1 CPU at 100%
  • Memory: 512MB (The one listed under System > Motherboard)
  • Display > Video: 12MB memory
I hope I did that right now :)
Seth
  • 59,332
Latedi
  • 123
Okay you most probably have a graphics card driver issue. There just may be a quick fix here. Try if you can rightclick on that desktop backround. If you get a menu then choose:
Change Desktop backround.
Thats just a backdoor to get into the system settings without having to revert to a terminal. If that works, You will be in the appearance tab of the systems settings. Click the all settings tab and go to
Software Sources
Here, go to the last tab (Additional drivers)and you may see a list of drivers for your graphics card. Choose the X.Org xserver, if its displayed.
This might bring your system back to being able to display Unity, and get you started
If that doesnt work then hit CNTRL-ALT-t to get a terminal and enter
sudo lshw -C display
Post the output back here.
gd luck
Issue was finally identified as:
https://forums.virtualbox.org/viewtopic.php?f=3&t=51727
uninstalling unity 3d and installing KDE desktop resolved this. (see comments below)
matv1
  • 756
I had this same problem earlier, but I was able to fix it by:
  1. Use both a boot disk AND a bootable flash drive. To make a bootable flash drive, follow these instructions. Put both the disk and the USB in your commuter, then restart. If the disk s ejected, push it back in. When you hear the startup chime, immediately press and hold C until it boots from the disk
  2. You may still see the background and nothing else. That's ok. What ended up working for me was to just wait a really long time. I saw the blank wallpaper, went to dinner with my family, and when I came back I saw a desktop with icons and everything.
There are several programs that will brick unity if used improperly. If you were doing any heavy hacking, you may have "broke" it. (I'm not a super linux techy, but a somewhat experienced computer user, so i'm speaking more from my trial and error process of trying to craft the "perfect" desktop for me) If you are super Unity attached, you might have to just reinstall ubuntu.
First see if you can log in with one of the other desktop enviroments (Gnome 3, Gnome classic are installed by default, just click on the Ubuntu logo on the login screen)
If that doesn't work
See if you can open the terminal with Ctrl-Alt-T,
Then try "sude apt-get install ubuntu-desktop"
If that doesn't work, install another desktop enviroment.
I just set up Ubuntu for the first time on my Windows 7 Asus laptop using VirtualBox, and I had the same problem of only getting the background screen. So I searched in google to find this.
However: in the meantime the problem fixed itself. It seems that I just had to wait a bit longer and then Ubuntu automatically continued the installation process.
So, just saying it may be a good idea to just wait a little and see what happens. I had the background screen showing only for about 10 - 15 minutes before the rest of the installation processes continued.
Of course, there might be another issue, but no harm in waiting as a first option :-)
