I'm trying to follow the instructions in this answer on how to copy the Ubuntu image to an SD card for the Raspberry Pi.
I get the following error using the imagewriter application:
Trying to unmount /dev/mmcblk0p1...
/dev/mmcblk0p1 successfully unmounted
Executing: dd if=/media/ewilson/KINGSTON/2012-08-08-wheezy-armel.img of=/dev/mmcblk0
The dd process ended with an error!
I have no idea how to troubleshoot this. Any ideas?
Eric Wilson
  • 1,016
are you root, or using sudo? you need to be, to write to a block device.
Jim Salter
  • 4,383
It seems it was an issue related to not having administrative privileges. I did the same thing with sudo imagewriter and it worked.
Eric Wilson
  • 1,016
