39
I'm having a rather strange problem with Dropbox that started a few weeks ago.
Dropbox will stop syncing with the message "Can't access Dropbox folder", and refuse to sync until I reboot.
I've tried restarting Dropbox and logging out, but nothing I seem to do will allow it to sync again short of a reboot.
This is not a permissions problem, as the permissions don't change when I suddenly lose access.
I've checked lsof for anything related to dropbox that might still be hanging on when I stop it. As far as I can tell nothing else other than Dropbox is accessing it's folders when this happens.
Jorge Castro
  • 73,717
if you put these in /etc/sysctl.conf:
fs.inotify.max_user_watches = 1048576
fs.inotify.max_user_instances = 256
it will fix the issue. You may have to run sudo sysctl -p for these settings to take effect.
Alternatively, if you are not interested in making these settings permanent, you may try the following commands...
sudo sysctl fs.inotify.max_user_instances=256
sudo sysctl fs.inotify.max_user_watches=1048576
In this case the settings will be lost after a reboot.
The problem is that the system has run out of inotify instances. You can check your syslog (e.g. by using tail -f /var/log/syslog) and if you see...
tail: inotify cannot be used, reverting to polling: Too many open file
then you know this is your issue. For me it was nepomuk.
user95987
  • 601
The fs.inotify.max_user_instances=256 fixed my immediate "Can't access dropbox folder" problem (Ubuntu 12.04).
It also cleared up an odd behavior I'd noticed, where the dropbox systray icon continually indicated file activity: The arrow circles cycling continually, though nothing was changing in my dropbox, and the "recently changed files" list remained unchanged.
A few moments after I changed fs.inotify.max_user_instances=256, the pointless cycling stopped.
Frank M
  • 316
-1
In one of the forums, someone mentioned it is due to inotify. They have this solution/workaround.
  • disable desktop search (in kde nepomuk+tracker, in gnome tracker)
  • reboot (logout didn't help)
fossfreedom
  • 174,526
TuEk
This usually happens because sysctrl has run out of inotify instances. The following 2 commands will normally fix the issue.
Silas Palmer
  • 109
