I have a desktop PC with Win 7 and Ubuntu 12.04 and default GRUB, also, i have a wifi USB adapter plugged which automatically connect to my personal wifi.
My problem is this:
when i boot into Win 7 the wifi works fine, then i reboot to ubuntu and the wifi doesn't work automatically. Is fixed if i plug the USB-wifi out and in again.
Weird thing is if I reboot from Ubuntu to Ubuntu (and the wifi was working) it connects automatically as it should. If i reboot from ubuntu to ubuntu and the wifi was not working it wont connect automatically.
So theres seems to be 'something' that messes up things in the very moment i boot to Windows 7 via GRUB.
¿how to fix that? i constantly change from one system to another so is quite annoying to plug the USB in and out every time.
Hardware info: USB wifi adapter: TP-Link TL-WN321G V4 using chipset: "ID 148f:2070 Ralink Technology, Corp. RT2070 Wireless Adapter" (got it from $ lsusb) it works via the driver: rt2800usb
This is a fresh install Jan 23 2013 fully up to date. I have this problem since 12.04 came out, and 12.10 wont fix it.
when the USB wifi is not working it still detects it:
$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 003: ID 046d:c52f Logitech, Inc. Wireless Mouse M305
Bus 002 Device 004: ID 4971:ce04 SimpleTech
Bus 002 Device 005: ID 04cf:0022 Myson Century, Inc. OCZ Alchemy Series Elixir II Keyboard
Bus 002 Device 006: ID 148f:2070 Ralink Technology, Corp. RT2070 Wireless Adapter
then i unplug and plugin again:
$ lsusb
Bus 002 Device 007: ID 148f:2070 Ralink Technology, Corp. RT2070 Wireless Adapter
and there is that small change.
EDIT 1:
after some reading i got additional information: (this happens when the wifi wont connect)
$ sudo ifup wlan0
[sudo] password for marcos:
Ignoring unknown interface wlan0=wlan0.
$ iwconfig
lo        no wireless extensions.
wlan0 IEEE 802.11bg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off Power Management:on
eth0 no wireless extensions. $ ifconfig wlan0 wlan0 Link encap:Ethernet direcciónHW <hidden MAC address>
ACTIVO DIFUSIÓN MULTICAST MTU:1500 Métrica:1 Paquetes RX:0 errores:0 perdidos:0 overruns:0 frame:0 Paquetes TX:0 errores:0 perdidos:0 overruns:0 carrier:0 colisiones:0 long.colaTX:1000 Bytes RX:0 (0.0 B) TX bytes:0 (0.0 B)
and this are the changes after i unplug and re-plug the USB wifi
$ iwconfig wlan0
wlan0     IEEE 802.11bg  ESSID:"Red de Lourdes"
          Mode:Managed  Frequency:2.412 GHz  Access Point: <hidden MAC address>
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Power Management:on
          Link Quality=59/70  Signal level=-51 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:145  Invalid misc:96   Missed beacon:0
$ ifconfig wlan0
          Direc. inet:<hidden IP address>  Difus.:<hidden IP address>  Másc:<hidden IP address>
          Dirección inet6: <hidden IPv6 address> Alcance:Enlace
          ACTIVO DIFUSIÓN FUNCIONANDO MULTICAST  MTU:1500  Métrica:1
          Paquetes RX:2108 errores:0 perdidos:0 overruns:0 frame:0
          Paquetes TX:2259 errores:0 perdidos:0 overruns:0 carrier:0
          Bytes RX:845327 (845.3 KB)  TX bytes:395596 (395.5 KB)
Any way to make a Bash script to get the wireless to work? any other solution? is the GRUB at fault here?
You can activate the wlan by these commands instead of repluging:
sudo modprobe -r 8192eu
sudo modprobe 8192eu
You need change 8192eu to your own wlan name. If you don't know the name, search on google with keyword ID 148f:2070(your usb wlan's id which can be found by command lsusb).
Or you can just add the wlan name to /etc/modules:
sudo -i
echo 8192eu >> /etc/modules
exit
Then the wlan will be activated automatically when system start.
First you need to identify the driver for your USB wifi adapter. Execute the following command to get the list of network adapters lshw -C network Following is the kind of output you might notice
  *-network:0
       description: Wireless interface
       physical id: 1
       bus info: usb@3:5
       logical name: wlx542aa25b496d
       serial: 54:2a:a2:5b:49:6d
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8xxxu driverversion=5.0.0-32-generic firmware=N/A ip=172.16.61.0 link=yes multicast=yes wireless=IEEE 802.11
Check the driver and note it down. Assume it is rtl8xxxu and you can use following commands to unplug or plug the adapter via commands
sudo modprobe -r rtl8xxxu
sudo modprobe rtl8xxxu
Since this again is manual invocation, you can add the commands in /etc/rc.local Add the following code just before exit 0
sleep 1
modprobe rtl8xxxu
Int Ubuntu 18.04 the rc.local file doesn't exists, so you can create with sudo nano /etc/rc.local Add the following part which is taken from Ubuntu 16.04's stock /etc/rc.local file to automate it on system boot
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Then add the uplug/plug code before exit 0. You'll need to make the file executable by sudo chmod +x /etc/rc.local. Reboot and see if this works or not
Mink
This started happening to me after I installed Windows 10 alongside Ubuntu and I found SOLUTION on the link below that BIOS Secure Boot feature is causing the issue. No WI-FI adapter found after restarting
If you want to keep Secure Boot enabled, you can look into this article https://www.howtogeek.com/116569/htg-explains-how-windows-8s-secure-boot-feature-works-what-it-means-for-linux/ It mentions shim-signed package and how it might enable you to verify signatures... Don't know...
I disabled it.
Bramastic
  • 101
