61
Below is what I know:
I have to add this below line in sudoers file to give rights to the user for particular task.
user_name ALL=NOPASSWD: /usr/bin/apt-get install
In this case I want to give access to this user to restart 2 services (i.e. Apache and MySQL) with all install rights.
Using the above line, I have given him all install rights, now do I have to add same line two more times to give the rights for services? Or can I just add those commands in the same line, separated by comma or something?
lucke84
  • 105
Hrish
  • 2,399
I have solved the issue by creating a new group for limited admin rights... name of that group is LimitedAdmins after that I updated the sudoers file as below.
The line I appended is:
%LimitedAdmins ALL=NOPASSWD: /usr/bin/apt-get*, /etc/init.d/apache2 restart
This is the complete /etc/sudoers file:
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of directly modifying   his file.
# See the man page for details on how to write a sudoers file.
Defaults    env_reset
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
#includedir /etc/sudoers.d
%domain_name\\administrators ALL=(ALL) ALL
It works perfectly fine in case if your system is domain or not.
Hrish
  • 2,399
17
Looks like comma is what you need.
Cmnd_Alias PRINTING = /usr/sbin/lpc, /usr/bin/lprm
user3 ALL= PRINTING
Source
Karthik T
  • 2,116
FWIW, I was wondering the same thing as the OP, and it looks like you can as well just duplicate the lines, e.g.
user_name ALL=NOPASSWD: cmd1
user_name ALL=NOPASSWD: cmd2
user_name ALL=NOPASSWD: cmd3
What I ended up doing was (Similar to what you are looking for):
## PRTG monitoring
Cmnd_Alias PRTG = /bin/cat /proc/loadavg, /bin/df, /var/prtg/scripts/check_proc.sh
prtg ALL = NOPASSWD: PRTG
Inside: /etc/sudoers.d/666-prtg
(666, because... well... prtg IS a windows based monitoring tool you know)
