13
At work we have to use Sonicwall Netextender to connect over VPN. The NetExtender client works fine on Windows x64 for me, but when using the same settings in my Ubuntu , the connection seems to work fine at first - But after just some packages have been sent, it slows down to almost 0 or 0 ( the connection is still up and seems fine)
Some other people at work have the same NetExtender problem with their Ubuntusetups, so we belive it's some failure with the NetExtenderclient - or that some workaround is needed with it.
So the Question is: Has anyone had success in using NetExtender on Ubuntu 12.x, and what specific settings did you use?
Also - are there any Open Source alternative NetExtender clients we could use instead of the SonicWalls one?
BTW (I tried stuff like this http://www.webantix.net/2012/02/sonicwall-netextender-on-ubuntu-x64.html)
Also tried with latest NetExtenderPackage "NetExtender.Linux.7.0.741.x86_64" and it's the same symptoms - i can connect successfully, fetch about one webpage, and then everything just seem to stall. I also upgraded to Ubuntu 13.04.
Irritating that it works flawlessly on the same machine with Windows 7 in dualboot, same settings.
Beamie
  • 313
See Franck Routiers Post:
Note, you'll have to have the Java Development Kit installed on your System.
1) go to https://sslvpn.demo.sonicwall.com/cgi-bin/welcome
2) log in with demo/password
3) click on NetExtender icon, this will download a tar.gz with the client
4) sudo ln -s /lib/x86_64-linux-gnu/libssl.so.1.0.0 /usr/lib/libssl.so.6
5) sudo ln -s /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 /usr/lib/libcrypto.so.6
6) un-tar the client, make install script executable and launch install
You're done.
Connect with :
sudo netExtender -u user -p password -d domain server
(and see man netExtender)
Sandro
  • 251
https://www.sonicwall.com/support/knowledge-base/how-can-i-download-and-install-netextender-on-linux/180105195559153/
Installing with rpm had this issue, download the .tgz version and install, that fixed my issue in ubuntu 16.04 version
Not sure if you got a solution to this or not, but Dell Sonicwall just released a firmware update to the NSA series that somewhat addresses this type of issue. I was having similar "trailing off" issues with my windows client. The Global VPN client would work fine, but the Netexender would slow to a crawl after a couple minutes. This firmware update has increased the throughput by a factor of at least eight and the speed stays constant!
