I'm trying out Ubuntu's live cd and have booted in from a USB. I want to check if it will work with my VPN or not. I already have Network Manager installed, but when I go to Configure VPNs, I can only see PPTP as an option, while I need to add an OpenVPN type of VPN.
Following the instructions on my VPN's documentation I tried to install openvpn using this:
sudo apt-get install network-manager-openvpn
But I get the response:
Reading package lists... Done
Building dependency tree
Package network-manager-openvpn is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'network-manager-openvpn' has no installation candidate
Any ideas what the issue is?
Robie Basak
  • 15,910
VPNDude
network-manager-openvpn is in universe, which isn't included on the live image by default. But you can still temporarily install it in the live environment. Assuming that you're using 12.10, add this line to your /etc/apt/sources.list:
deb http://archive.ubuntu.com/ubuntu quantal universe
Then run sudo apt-get update, and try sudo apt-get install network-manager-openvpn again.
I'm not sure if you need to restart Network Manager after installing. If so, sudo restart network-manager should work.
Robie Basak
  • 15,910
