I'm new to DNS and making a DNS server. I've read through the bind9 server how to (at https://help.ubuntu.com/community/BIND9ServerHowto) and several tutorials online on setting up a bind9 server in ubuntu. I haven't gotten any of them to work yet.
I'm trying to get fivestones.desonia to resolve to my computers LAN ip address of 192.168.1.139.
My named.conf.options file:
options {
directory "/var/cache/bind";
// If there is a firewall between you and nameservers you want
// to talk to, you may need to fix the firewall to allow multiple
// ports to talk. See http://www.kb.cert.org/vuls/id/800113
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
forwarders {
8.8.8.8;
8.8.4.4;
// If BIND logs error messages about the root key being expired,
// you will need to update your keys. See https://www.isc.org/bind-keys
dnssec-validation auto;
auth-nxdomain no; # conform to RFC1035
listen-on-v6 { any; };
My named.conf.local file:
#// Do any local configuration here
#// Consider adding the 1918 zones here, if they are not used in your
#// organization
#//include "/etc/bind/zones.rfc1918";
zone "fivestones.desonia" {
type master;
file "/etc/bind/zones/db.fivestones.desonia";
zone "1.168.192.in-addr.arpa" {
type master;
notify no;
file "/etc/bind/zones/db.192";
my /etc/bind/zones/db.192 file:
; BIND reverse data file for local loopback interface
$TTL 604800
@ IN SOA ns.fivestones.desonia. root.fivestones.desonia. (
2013012113 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Negative Cache TTL
@ IN NS ns.
10 IN PTR ns.fivestones.desonia.
my /etc/bind/zones/db.fivestones.desonia file
; BIND data file for local loopback interface
$TTL 604800
2013012110 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
@ IN NS ns.fivestones.desonia.
ns IN A 192.168.1.139
server IN A 192.168.1.139
www IN A 192.168.1.139
I sudo service bind9 restart and then this is my tail -f /var/log/syslog:
Jan 21 23:47:25 media-server named[16726]: command channel listening on 127.0.0.1#953
Jan 21 23:47:25 media-server named[16726]: command channel listening on ::1#953
Jan 21 23:47:25 media-server named[16726]: zone 0.in-addr.arpa/IN: loaded serial 1
Jan 21 23:47:25 media-server named[16726]: zone 127.in-addr.arpa/IN: loaded serial 1
Jan 21 23:47:25 media-server named[16726]: zone 1.168.192.in-addr.arpa/IN: loaded serial 2013012113
Jan 21 23:47:25 media-server named[16726]: zone 255.in-addr.arpa/IN: loaded serial 1
Jan 21 23:47:25 media-server named[16726]: zone fivestones.desonia/IN: loaded serial 2013012110
Jan 21 23:47:25 media-server named[16726]: zone localhost/IN: loaded serial 2
Jan 21 23:47:25 media-server named[16726]: managed-keys-zone ./IN: loaded serial 2
Jan 21 23:47:25 media-server named[16726]: running
But when I try to host -l fivestones.desonia I get
; Transfer failed.
Host fivestones.desonia not found: 9(NOTAUTH)
; Transfer failed.
And if I try to ping fivestones.desonia I get ping: unknown host fivestones.desonia.
If I host google.com I get
google.com has address 74.125.227.96
google.com has address 74.125.227.97
google.com has address 74.125.227.98
google.com has address 74.125.227.99
google.com has address 74.125.227.100
google.com has address 74.125.227.101
google.com has address 74.125.227.102
google.com has address 74.125.227.103
google.com has address 74.125.227.104
google.com has address 74.125.227.105
google.com has address 74.125.227.110
google.com has IPv6 address 2607:f8b0:4000:800::1004
google.com mail is handled by 20 alt1.aspmx.l.google.com.
google.com mail is handled by 30 alt2.aspmx.l.google.com.
google.com mail is handled by 40 alt3.aspmx.l.google.com.
google.com mail is handled by 50 alt4.aspmx.l.google.com.
google.com mail is handled by 10 aspmx.l.google.com.
so at least that's working. But host fivestones.desonia does nothing.
If I dig fivestones.desonia I get
; <<>> DiG 9.8.1-P1 <<>> fivestones.desonia
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 57727
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;fivestones.desonia. IN A
;; AUTHORITY SECTION:
fivestones.desonia. 604800 IN SOA ns.fivestones.desonia. root.fivestones.desonia. 2013012110 604800 86400 2419200 604800
;; Query time: 1 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Mon Jan 21 23:51:40 2013
;; MSG SIZE rcvd: 80
...which seems like it's working. But it doesn't work.
And finally if I wget fivestones.desonia (the computer is running apache) I get
Resolving fivestones.desonia (fivestones.desonia)... failed: Name or service not known.
wget: unable to resolve host address `fivestones.desonia'
What am I doing wrong? Or what other info would you need to help me figure this out? Thanks so much!
