I am new to linux. I installed xubuntu using a usb live disk. It installed correctly however grub (the multi os loader) is on the usb. When I boot without the usb it only loads windows. The installation is good since I can boot from the usb, once booted I can remove the stick and verify that the installation is on the hard drive.
How do i move safely move the boot mechanism from the usb to the hard drive?
guntbert
  • 13,475
Alex
  • 41
Just found the answer to my own question in case someone needs this in the future. The trick is to use boot-repair and make sure to select advance then install the mbr on the main hard drive (eg sba1). Follow this url for more info - http://www.howtogeek.com/114884/how-to-repair-grub2-when-ubuntu-wont-boot/
Alex
  • 41
Boot with your usb attached, and type at a root terminal:
grub-setup /dev/sda
Remove your usb and reboot.
