Received the following error when attempting to install from Terminal:
Selecting previously unselected package dassault-systemes-draftsight.
(Reading database … 211618 files and directories currently installed.)
Unpacking dassault-systemes-draftsight (from …/Downloads/draftSight.deb) …
access control disabled, clients can connect from any host
Now receiving system error notification that it's half installed and causing the error. It's crashing the Software Center, I cannot figure out how to kill the offending dpkg or how to un-install what is installed to start over.
sudo apt-get remove dassult-systemes-draftsight
[sudo] password for user:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Made a bit more progress:
Reading package lists... Done
Building dependency tree
E: The package dassault-systemes-draftsight needs to be reinstalled, but I can't find an archive for it.
dpkg/Status shows half installed:
Package: dassault-systemes-draftsight
Status: install reinstreq half-installed
Priority: extra
Section: applications
Architecture: i386
Version: 2012.7.347
But Terminal says it's not there:
user:~$ sudo dpkg --force-remove-reinstreq --remove dassult-systemes-draftsight
dpkg: warning: ignoring request to remove dassult-systemes-draftsight which isn't installed
user@computer:~$ sudo dpkg -e DraftSight
dpkg-deb: error: failed to read archive `DraftSight': No such file or directory
Elder Geek
  • 36,752
First run :
sudo rm /var/lib/dpkg/lock
Then:
sudo dpkg -r dassault-systems-fraftsight
If it is successful or not, then run
gksudo gedit /var/lib/dpkg/status
In the resulting Gedit, remove the whole section starts with :
Save and Close it.
