I have a GT 430 Nvidia, was working fine till I upgraded to 12.04 yesterday. Apparently, nvidia decided to remove the overscan slider. I can't adjust to fix the overscan then, except in the xorg.conf which I can't edit. Even if I can, I'm not sure it would fix the problem.
I know the resolution that fits my TV as I have this issue in windows and in Ubuntu, its 1824x1026. Strange resolution, but it works. Is there a way I can either edit xorg.conf or if I can change it without doing so? Am running the latest drivers (not the experimental ones).
The issue with the xorg.conf is that it won't let me edit due to permission.
Fultic
xorg.conf cannot be edited without root permissions. To edit it, do this:
  1. Press Alt+F2. This will open the "Run Application" window.
  2. Type gksu gedit /etc/X11/xorg.conf and press Enter.
  3. Enter your password when prompted and press Enter.
  4. gedit will open with xorg.conf.
  5. Make your modifications and press Ctrl+S to save.
  6. Reboot.
Kalle Elmér
  • 9,216
