Same question as how-to-downgrade-a-package-via-apt-get, except what if it's on a newly deployed server and the archived .deb is not there?
For example, https://launchpad.net/ubuntu/precise/amd64/wget tells me the previous version is 1.13.4-1ubuntu2, and I have 1.13.4-2ubuntu installed:
$ dpkg -l | grep wget
ii  wget                            1.13.4-2ubuntu1            retrieves files from the web
When I try to force the version:
vagrant@es2:~$ sudo apt-get install wget=1.13.4-1ubuntu2
Reading package lists... Done
Building dependency tree
E: Version '1.13.4-1ubuntu2' for 'wget' was not found
Is there a way to "ask" apt-get update to fetch information/URLs/etc. about older versions?
Is the solution to run my own apt repository with the versions I want?
gak
  • 142
wget http://launchpadlibrarian.net/85655688/wget_1.13.4-1ubuntu2_i386.deb
result
--08:29:45--  http://launchpadlibrarian.net/85655688/wget_1.13.4-1ubuntu2_i386.deb
           => `wget_1.13.4-1ubuntu2_i386.deb'
Resolving launchpadlibrarian.net... 91.189.89.229, 91.189.89.228
Connecting to launchpadlibrarian.net|91.189.89.229|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 282,988 (276K) [application/x-debian-package]
100%[====================================================>] 282,988      445.03K/s
08:29:46 (443.76 KB/s) - `wget_1.13.4-1ubuntu2_i386.deb' saved [282988/282988]
As long as you have an internet connection you can wget all the debs you want. After this you can try to install it with USC (might not work due to dependencies) or with dpkg but you might need to wget the dependencies 1st too.
In this case wget ...
Package relationships. Depends on
dpkg (>= 1.15.4)
libc6 (>= 2.11)
libidn11 (>= 1.13)
libssl1.0.0 (>= 1.0.0)
Package relationships. Conflicts
wget-ssl
By the way: I searched https://launchpad.net for wget 1.13.4-1ubuntu2 and use the link on this page https://launchpad.net/ubuntu/precise/i386/wget/1.13.4-1ubuntu2 to locally download the file named wget_1.13.4-1ubuntu2_i386.deb (276.4 KiB).
In theory you can create the download from memory for other files.
Rinzwind
  • 309,379
