If you don't want to move around boot files, you could try changing the boot sequence manually:
Get into ubuntu manually and check the current boot sequence and their ID's using:
sudo efibootmgr -v
then change the boot sequences using -o and the ID's (in boot order left to right):
sudo efibootmgr -o 0000,3000,0001,2001,2002,2003
Example:
1. Show current boot settings
$ sudo efibootmgr -v
BootCurrent: 0001
Timeout: 2 seconds
BootOrder: 0001,3000,0000,2001,2002,2003
Boot0000* ubuntu HD(2,GPT,c451cb3c-a684-45ac-9925-4046e57c40cb,0x145800,0x82000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* Windows Boot Manager HD(2,GPT,c451cb3c-a684-45ac-9925-4046e57c40cb,0x145800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot2001* USB Drive (UEFI) RC
Boot2002* Internal CD/DVD ROM Drive (UEFI) RC
Boot3000* Internal Hard Disk or Solid State Disk RC
Boot3001* Internal Hard Disk or Solid State Disk RC
Boot3002* Internal Hard Disk or Solid State Disk RC
Boot3003* Internal Hard Disk or Solid State Disk RC
2.Change boot order (we want to start ubuntu first, that will show the boot menu at startup):
Note that the first try gave an error because it couldn't find Boot2003 (floppydisk drive?), as you can see it is recreated after reboot though.
$ sudo efibootmgr -o 0000,3000,0001,2001,2002,2003
Invalid boot order entry value: 0000,3000,0001,2001,2002,2003
Boot entry 2003 does not exist
BootCurrent: 0000
Timeout: 2 seconds
BootOrder: 0000,3000,0001,2001,2002
Boot0000* ubuntu
3.Reboot. The boot menu should now appear. (2003 is re-added automatically):
BootCurrent: 0000
Timeout: 2 seconds
BootOrder: 0000,3000,0001,2001,2002,2003
