19
I need to configure an Ubuntu server to follow a strict company password policy that specifies the following:
  • at least one upper case
  • at least one lower case
  • at least one digit
  • at least one special character
I've had a look around and all I have found is the instructions for specifying the password length; but, I have yet to find something that relates to specifying the content of the password regarding the above points.
Any help would be appreciated.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Stephen RC
  • 4,920
Update January 2023: the library pam_pwquality.so has in many/most cases superceded the use of pam_cracklib.so. pam_pwquality.so should be backwards compatible with pam_cracklib. See pam_pwquality.so man pages for usage details & examples.
Password complexity is enforced by the pam_cracklib module.
In order to modify the password policy for your local machine, you will need to modify your /etc/pam.d/common-password file.
From a terminal window (Ctrl+Alt+T), enter the following command:
sudo vi /etc/pam.d/common-password
Add the following line to the file (before pam_unix.so or whichever PAM module is used primarily for authentication, as can be seen from examples in the manpage) and save the file:
password requisite pam_cracklib.so ucredit=-1 lcredit=-1 dcredit=-1  ocredit=-1
This statement implements the following password requirements:
  • dcredit == digit
  • ucredit == upper-case character
  • lcredit ==lower-case character
  • ocredit == other character (special characters, including ! , @ # $ %)
This should satisfy your requirements.
You could also use the variables minlength and retries to further restrict the password requirements.
Here is another good example of modifying a password policy in this manner would be placing the following line in the /etc/pam.d/common-password file:
password requisite pam_cracklib.so retry=3 minlen=10 difok=3 ucredit=-1 lcredit=-1 dcredit=-1  ocredit=-1
This entry will set a maximum of three attempts at getting an acceptable password with a 10-character minimum length.
This sets the requirement for users to have a minimum of three characters different from the last password.
This will also fulfill the requirement of having the password contain at least one each of digit, lower-case character, and upper-case characters.
See also this article on setting up stronger password policy rules in linux.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
There's a fork of pam_cracklib by Tomas Mraz: pam_pwquality with slightly better options.
Add it with apt install libpam-pwquality or passwd will complain:
Module is unknown
caduceus
  • 280
