Get needed software
sudo apt-get install gpac mkvtoolnix
Extract video and audio from matroska file
First you need to check what tracks the matroska file contains with
mkvmerge --identify video.mkv
File 'video.mkv': container: Matroska
Track ID 1: video (V_MPEG4/ISO/AVC)
Track ID 2: audio (A_AC3)
Then extract video and audio according to their tracks with:
mkvextract tracks video.mkv 1:video.h264 2:audio.ac3
Extracting track 1 with the CodecID 'V_MPEG4/ISO/AVC' to the file 'video.h264'. Container format: AVC/h.264 elementary stream
Extracting track 2 with the CodecID 'A_AC3' to the file 'audio.ac3'. Container format: Dolby Digital (AC3)
Progress: 100%
Mux audio and video into mp4 containter
MP4Box -fps 24 -add video.h264 -add audio.ac3 video.mp4
AVC-H264 import - frame size 1280 x 720 at 24.000 FPS
Import results: 31671 samples - Slices: 5672 I 125048 P 122648 B - 32288 SEI - 4936 IDR
AC3 import - sample rate 48000 - 6 channels
Saving to video.mp4: 0.500 secs Interleaving
I had to add -fps 24 option because MP4Box didn't detect video fps correctly. Depending on usage AC3 audio track should be re-encoded into something else before muxing.
Now you have remuxed streams from matroska container into mp4 container without losing any quality.
EDIT:
MP4 doesn't officially support AC3 audio so the audio track should be converted into a supported format (eg. AAC, MP3) if you want the file to be playable with something else than VLC.
