While following the instructions here (either 12.10 or 12.04) It begins good. Brings up the selection menu to boot from USB or to install. Then starts booting fine but never finishes. It gets stuck on the purple screen with the Ubuntu logo. The progress dots freeze. If I leave it, after a while, the screen gets mangled with random boxes as if the graphics card is going bad.
This is on a Asus G51J ... should I assume there is some type of a driver issue ?
Mukund
  • 2,122
Thomas An
  • 121
It's a driver issue that I solved doing this:
  1. Press any key before the Ubuntu installation welcome screen (to open the "Ubuntu CD Advanced Welcome Page Options".
  2. Press F6 and select the nomodeset option and finish the installation.
  3. Hold the shift key while booting from the new installation (to access the GRUB options) and select the recovery mode in the GRUB options.
  4. Using the recovery mode, enable Internet access and open the root console to execute this commands:
    sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
    sudo apt-get update
    sudo apt-get install nvidia-current
    exit
