I have this two-monitor configuration that works flawlessly in the default 12.10 GNOME wm. This is my xorg.conf:
Section "Monitor"
    Identifier "VGA0"
    Option "Enable" "true"
    Modeline "1920x1200_60.00"  193.16  1920 2048 2256 2592  1200 1201 1204 1242  -HSync +Vsync
    Option "PreferredMode" "1920x1200_60.00"
EndSection
Section "Monitor"
    Identifier "LVDS0"
    Modeline "1368x768_60.00"  85.86  1368 1440 1584 1800  768 769 772 795  -HSync +Vsync
    Option "PrefferedMode" "1368x768_60.00"
EndSection
Section "Device"
    Identifier "Radeon0"
    Driver "radeon"
    Screen 0
EndSection
Section "Device"
    Identifier "Radeon1"
    Driver "radeon"
    Screen 1
EndSection
Section "Screen"
    Identifier "Big Screen"
    Device "Radeon0"
    Monitor "VGA0"
    DefaultDepth 24
    SubSection "Display"
        Depth 24
        Modes "1920x1200"
    EndSubSection
EndSection
Section "Screen"
    Identifier "Little Screen"
    Device "Radeon1"
    Monitor "LVDS0"
    DefaultDepth 24
        Depth 24
        Modes "1368x768"
    EndSubSection
EndSection
Section "ServerLayout"
        Identifier "My Layout"
        Screen 0 "Big Screen"
        Screen 1 "Little Screen" RightOf "Big Screen"
        Option "Xinerama" "true"
EndSection
However, awesome wm that I am trying to set up right now is simply mirroring upper left part of the bigger screen to the smaller screen. Although I am happy that the resolution is right, I would obviously like to fill each screen with different content.
What am I doing wrong?
qbi
  • 19,515
if you wanted to try another easy/reversible option, you could make a copy of your xorg.conf, and then change "true" to "off" for xinerama.
these commands should do it:
cp /etc/X11/xorg.conf ~/xorg.conf
cat ~/xorg.conf | sed 's/true/off/g' > ~/xorg.conf.new
sudo cp ~/xorg.conf.new /etc/X11/xorg.conf
if something goes wrong, you can copy the original back using recovery mode and this command (edit user to be YOUR username of course)
sudo cp /home/user/xorg.conf /etc/X11/xorg.conf
the advantages of being able to use the second display are worth the effort and time to get it to work, in my opinion.
Joshua K
  • 313
i should be able to help. it's very similar to the setup i'm using. I think your problem is caused by Xinerama being on really. i suggest using the amdcccle program to configure it. You could also use lxrandr, it's very simple to use, but without installing anything else, use "gksudo amdcccle", expand the Display Manager group, and click on Xinerama. make sure there is no check there. It may be grey. if it's grey, select Display Manager, click the down arrow in the upper right corner of the icon representing monitor 2, and select "Multi-display" and then "multi-display desktop with displays 1". go back and make sure there's no check in Xinerama.
Joshua K
  • 313
